This could actually be one of a number of things, and it's difficult to tell just what's causing it. First of all, check what version of LabVIEW you have. I've heard of this happening with 6.0 and the problem was fixed in 6.0.2. There is a free update on the Web
here.
The problems I have heard of causing this were all fixed with the 6.0.2 update. They could occur when receiving chart history data. Also, I have heard of some problems with ActiveX containers combined with the use of the Visible property in a Property Node. Make sure you are not making any ActiveX objects on your front panel visible/invisible with a property node.
But
most importantly, make sure you've not using 6.0.
J.R. Allen
