Modbus over Ethernet/IP
Hello guys,
i am using LabView after quiet a long time and in addition i have to set up my own measurement setup.
I am thinking of using Wago 750-352 Fieldbus for couple of sensor measurements. I wish to implement http://www.wago.com/wagoweb/documentation/app_note/a2016/a201602e.pdf
The Document is pretty old. I found another document which does not mentions LabView at all.
Has any one used Modbus communication Wago Fieldbus coupler using LabView?
Please reply.
MandarG
(3,938 Views)
Just to clarify, you are trying to do Modbus over TCP/IP, no Ethernet/IP.  Ethernet/IP is an industrial protocol, similar to Modbus, over a TCP/IP connection.
There are a few Modbus libraries floating around that you could probably just use, assuming you know which registers you need to read/write from/to.
GCentral
(3,928 Views)
For our devices I use ModBus serial and over TCP. We have a lot of dedicated ModBus commands. So the standard libs won't help.
I just made my own ModBus drivers for serial and TCP.
This VI is just to show how the ModBus TCP communication is done. Maybe it can help you to build your VI's
Kees
(3,920 Views)
