12-14-2011 08:25 AM
in my measurement configuration I have a network analyzer connected to a PC using GPIB interface (NI PCI-GPIB, default setting).
The control software is HTBasic from TAMS which always uses the GPIB in the asynchronous way.
The controller should be fast enough (dual core @3 GHz)
Sometimes the transfer of binary data between NWA and PC fails. I learned that one byte will be lost.
I tried to find the cause of this, but in vain up to now.
More details:
A GPIB analyzer protocol displays all bytes, in the parallel NI-Spy log one byte is missing.
Here is the GPIB analyzer protocol, the relevant byte is underlined:
-- -- -- a 00001010 0 0 0 1 0 0 1 1 DAB
-- -- -- 1d 00011101 0 0 0 1 0 0 1 1 DAB
-- -- -- ? 3f 00111111 0 0 0 1 0 0 1 1 DAB
-- -- -- e2 11100010 0 0 0 1 0 0 1 1 DAB
-- -- -- 90 10010000 0 0 0 1 0 0 1 1 DAB
-- -- -- 91 10010001 0 0 0 1 0 0 1 1 DAB
-- -- -- > 3e 00111110 0 0 0 1 0 0 1 1 DAB
-- -- -- a7 10100111 0 0 0 1 0 0 1 1 DAB
-- -- -- e0 11100000 0 0 0 1 0 0 1 1 DAB
-- -- -- 1c 00011100 0 0 0 1 0 0 1 1 DAB
The export of NI-Spy in this section shows the following result (again with underline in the important section):
1227750. Asynchrone I/O neu synchronisiert für ibrda()
Prozess-ID: 0x00000900 Thread-ID: 0x0000090C
Startzeitpunkt: 09:40:40.809 Aufrufdauer 00:00:00.000
ibsta: 0x2164 iberr: 0 ibcntl: 457(0x1c9)
Ausgangspuffer
00000000: 8F 77 7A BF BB 42 53 3E 95 23 79 BF C7 3A 6B 3E .wz..BS>.#y..:k>
.etc
000001C0: 59 FE 1C 3F ED FE 91 3E 0A Y..?...>.
1227751. ThreadIbcntl()
1227752. ibrda(GPIB0, 0x01CFC503, 5159 (0x1427))
1227753. ibwait(GPIB0, 0x0000)
1227754. Asynchrone I/O neu synchronisiert für ibrda()
ibsta: 0x2164 iberr: 0 ibcntl: 17(0x11)
Ausgangspuffer
00000000: 0A 1D 3F E2 90 91 3E A7 E0 1C 3F E0 3E 91 3E 8F ..?...>...?.>.>.
00000010: D3 .
1227755. ThreadIbcntl()
What is obvious is that
- the binary stream is split up at bytes 0x0a (although the application reads in the stream with one command: "ENTER @Stream;Array(*)") which doesn't make a problem.
- some bytes before the missing byte there are two consecutive bytes 0x0a (may be by chance)
- after the missing byte the stream is split up again, but here (there is only one occurrence of this) NOT at 0x0a
What I have tried:
- It does not help setting the interface to "No autopolling"
- No other device is on the bus
- The NWA does not send a SRQ
What I want to know:
- can the application have an influence on the content of the NI-Spy? Is it the driver or the application?
- How can I prevent this?
I hope there is someone being able to help as I don't know how to proceed.....
Many thanks in advance.
12-23-2011 07:39 AM
after inspecting the two logs for several times I was not able to determine where I should find a lost byte.
Can you specify where there is something lost?
Best regards and a merry christmas,
Frank
12-27-2011 02:08 PM
0x0A is the default termination character. so with term char enabled the read stops when it sees a 0x0A
Drop one of these before your read and read the number of bytes you expect
01-02-2012 03:43 AM
Dear Frank,
thank you for checking my request. Merry Xmas as well. This is the reason why the reply is so late...
You are right, I copied the wrong section and marked the wrong 0x1c byte. The relevant logs are shortly afterwards:
GPIB-Analyzer:
-- -- -- 8f 10001111 0 0 0 1 0 0 1 1 DAB
-- -- -- d3 11010011 0 0 0 1 0 0 1 1 DAB
-- -- -- c7 11000111 0 0 0 1 0 0 1 1 DAB
and the NI-Spy log is here:
Ausgangspuffer
00000010: D3 .
1227756. ibrda(GPIB0, 0x01CFC514, 5142 (0x1416))
ibsta: 0x0 iberr: 0 ibcntl: 0(0x0)
1227757. ibwait(GPIB0, 0x0000)
ibsta: 0x64 iberr: 0 ibcntl: 0(0x0)
1227758. ibwait(GPIB0, 0x0000)
1227759. ibwait(GPIB0, 0x0000)
1227760. ibwait(GPIB0, 0x0000)
1227761. ibwait(GPIB0, 0x0000)
1227762. ibwait(GPIB0, 0x0000)
ibsta: 0x2164 iberr: 0 ibcntl: 626(0x272)
1227763. Asynchrone I/O neu synchronisiert für ibrda()
Ausgangspuffer
00000000: 3F C7 14 91 3E D3 2A 1D 3F 8F 61 90 3E 5A DC 1C ?...>.*.?.a.>Z..
I ask you to look again into this code...
Sorry for the inconvenience caused so far.
Best regards
Andy
