01-05-2012 01:36 PM
I would like to start out by saying I am definately a greenhorn when it comes to LabView and its hardware so if this is the wrong place for this question I apologize. I am looking to introduce LabView and the hardware National Instruments offers into my research. The end result I am looking for is to measure the magnetic field of a rare earth magnet using LabView capable instrumentation, hardware, and software. I can't quite wrap my head around the hardware NI offers and I was wondering if you all could shed some light.
Right now what looks the most intriguing is the CompactDAQ system. I think I might be able to adapt it to my needs but even though I have done plenty of searching I cannot find how or what equipment it is used with. I might be completely off track here so if I am please let me know. I want to eventually interface a Gauss/Tesla meter with labView to automatic meaurements and analyze/plot the appropriate data.
I was thinking I could acquire an appropriate Gauss/Tesla meter that outputs a voltage or current and use the CompactDAQ system to enable LabView to analyze the data.
Am I on the right track? Can you provide some suggestions?
01-05-2012 02:58 PM
Or simply locate a meter with an RS-232 connection. Then all you would need at most is a USB-RS232 converter. If you found a meter with an Ethernet connection, you might not have to spend a thing.
Even if you wanted to use a meter that only had an analog output, a cDAQ system sounds like extreme overkill for a single output.
Typically, some one starts by selecting an appropriate sensor/instrument first. You are doing it the opposite way.
01-05-2012 04:14 PM
Every instrument I look at seems to ship with their proprietary software. I am concerned with interfacing LabView with the instrument. Do you have any experience or tips that you can share about selecting a proper instrument?
01-05-2012 04:16 PM
You could look at the Instrument Driver Network to see if a NI supported driver exists for a specific instrument.
01-05-2012 05:57 PM
I have done that many times. The only issue is that the only Gauss meters that seem to have drivers are way out of my budget.
01-05-2012 09:21 PM
01-06-2012 02:22 PM
In what manner? to me it seems you have three choices?
What's your total budget in time and materials?
01-06-2012 04:38 PM
I have a budget of about $1200. Do you have experience with buying instruments and making drivers? is that a common thing to do?
01-06-2012 04:51 PM
Well, yes
This is why I asked about you budget in terms of time and money. I do not have the bandwidth to take on other tasks but you are going to spend either time or pay for time invested. A large investment would be involved in either (For simple 1 measurement drivers the going rate is in the range of X.x-Y.yK$ per communications bus with a bonus for certification as PnP(proj)style) Asume a Certified LabVIEW Developer will spend 8 man hours learning coding documenting and submitting a project at normal billing rates.
01-06-2012 05:10 PM
Well I want to learn ow to do it myself, which is why I came here. I am a developer myself, just not in LabView and I am trying to pick up the "language". Do you know of any good places to start learning how to write custom instrument drivers?
