12-10-2012 06:21 PM
I aquired the VI with the et24xx driver from the NI Insturment Driver Network
12-11-2012 01:08 PM - edited 12-11-2012 01:10 PM
Hi Gibran,
If the device is behaving in an unexpected way, it is possible the driver is not being used as the developer intended, or it is incompatible with your device. Since we have determined via a loopback test that you can successfully send serial commands, it would seem likely the problem is with the driver use, specific to what commands are being sent to your device. To better understand the driver, I would recommend looking at the software reference provided by Eurotherm, and dig into the LabVIEW code of the driver software to see what commands are being sent.
Warm Regards,
06-21-2014 06:14 AM
Hi
I have the same problem. How do you solve the IDN? problem in MAX Test panel.
thanks
06-23-2014 12:53 PM
Hi new_ingenieur,
Can you create a new thread for this question? This thread is several years old. A new thread will likely get more traffic.
