MODBUS Through NI USB 6008?
Hello.
I'm trying to control a VFD from my PC using Labview (could use something else if you suggest it is better).
After I get the basic control down I need to start adding PID control to it.
Can I use the Digital I/O of the NI USB as a port to communicate with the VFD with MODBUS protocol?
This might be completely far away from reality but I'm giving it a go.
Thanks.
(2,411 Views)
The digital IO is software timed, so you never can reliably get to the timing.
Modbus can communicate over several digital busses, serial and tcp/ip as normal.
So depending on your instrument set you have to choose.
greetings from the Netherlands
(2,404 Views)
Thanks for the quick reply
So I will have to use a different USB from my laptop to connect directly to the VFD and use Labview MODBUS modules to talk to it?
(2,400 Views)
indeed
(2,375 Views)
