12-10-2008 11:39 PM - edited 12-10-2008 11:45 PM
Hi, I am running into a problem with NI MAX while trying to setup a VISA server/client system. I had first tried VISA server 4.3 but it would not even allow me to save the port settings on the server. When I tried to connect to the server, the from a remote machine to access the RS232 ports, it would either crash NI MAX or do nothing depending on how I tried to set it up. If I right click on the Remote System on the right configuration pane and follow the wizard through, it does not do anything, if I go to the tool bar to Tools-NI VISA-VISA Options and follow the wizard through, NI MAX crashes upon completion. I then went online and got the lattest 4.4.1 version and tried that with the same results. I am also experiencing anomolies in saving some configurations in NI MAX leading me to question if there are some privileges issues. The OS is Windows XP Pro with SP2 on all machines. I am logged on with administrator rights and everything appears to have full read/write privileges yet I still run into problems. As to the problem of saving the port settings I tried manually setting the settings as described in
http://digital.ni.com/public.nsf/allkb/8EBAEC8A57BB48BE862574F90072D3DD
but with no success in version 4.3 but it did work fine when I upgraded to 4.4.1 with no changes to rights or privilages so some things seem kind of odd. Any help would be greatly appreciated.
Hardware Dell computers with Windows XP Pro and SP2
The server computer has a 16 port Rocket port RS232 port board
I will be accessing the ports with a program written in LV7.1 but I have not gotten to that point yet
Network is fine, I can ping the server computer from the client computer and the permissions are set in the server and the client is pointing to the right machine.
CS
Solved! Go to Solution.
12-11-2008 03:22 PM
Thank you for your post. There is a known issue with MAX crashing when you right-click on a remote server. This is documented in the KnowledgeBase here. This is a bug that should have been fixed with MAX version 4.5. MAX 4.5 should have been installed with VISA 4.4.1. Which version of MAX are you using? You can check by going to Help»About in MAX. If you don't have MAX 4.5, reinstall VISA 4.4.1 and ensure that MAX 4.5 is included in your installl.
Have a great day!
Todd V.
12-12-2008 11:55 AM
This site uses cookies to offer you a better browsing experience. Learn more about our privacy statement and cookie policy.
