Hi JiachunLin,
Please mention that you are using Chinese language for describing the issue (mention Chinese to be in contact with Chinese users). As I can understand with google translate, you have troubles with installing the drivers (incorrect versions shows up in NI MAX). Please correct me if I am wrong.
You can try to reinstall the drivers, using all the same versions. For example if you are using LabVIEW18, you should install NI VISA 18. Otherwise you can face an errors in NI MAX and in your applications. For the installations, it is recommended to use NI Package Manager
Regards
