07-09-2019 09:39 AM
I am looking for an industrial controller or a combination of controllers with all (or most) of the following specifications:
-6 Serial ports for connection to computers, balances, etc
-13 Solenoid drivers to control 12-24 volt solenoid valves (or similar)
-10 Sensor inputs for 19C Honeywell analog pressure or level sensors (or similar)
-3 Stepper Motor drivers for 12-24 volt motors
-3 PWM Motor drivers for 12-24 volt motors
-1-Wire interface to read temperature sensors
-2 Optically isolated inputs to sense voltage or contact closure
-4 CMOS 5 volt compatible outputs
-Remote LED display to show status of the valves
-Audible alarm
It would be great if someone can point me toward some options.
Thanks you.
Solved! Go to Solution.
07-10-2019 03:08 PM
The best option is to call NI and ask for Sales. There are Sales engineers that can help you with this.
According to your requirements, you can ask for a PXI or a cRIO device, and buy the boards or modules according to your needs.
