Alfred,
(This is the same response that I e-mailed you earlier today)
At this time it is not possible to do what you want with our driver and GPIB-ENET/100. The ENET/100 does support interface locking to where one computer can lock out others who are trying to access it via viLock or IBLCK, and VISA supports locking an instrument (resource) and not allowing any other processes on a single computer to access the resource (via viLock), but there is currently no implementation of locking a particular resource so that no other computer can access it.
Depending on what you are trying to do, it may be appropriate to force all the computers to "go through" a single VISA server, which could use viLock to lock other computers out, but each computer would be going
through this "gateway" computer to access the instruments. Another solution is to use multiple GPIB-ENET/100's. A third solution is to use some sort of network semaphores that can be held and released by each computer; the implementation of this solution would probably be up to the operating system if it even exists.
Hope this helps.
Scott B.
Applications Engineer
