07-31-2013 07:49 AM
Hello i'm having issues in the configuration of this instrument.
I downloaded the drivers from the site and put them in the folder \National Instruments\LabVIEW 2012\instr.lib
but i want to use this instrument also using the SCPI commands.
The first thing that I see is that in MAX I don't find the instrument in the Remote Systems. I did right click and created new but when I set the ip (192.168.32.55) but I got error "Unable to inizialize connection to remote target(s)".
Same problem if I try to write in the example VIs VICP::192.168.32.55
I'm sure the IP written before correct because I got no error with the ping in the prompt C:\
Where is the mistake?
07-31-2013 09:55 AM
Solved following this guide attached.
Many thanks to Leonard
