I am trying to get 4 signals from my bluetooth which is connected to a sensor. later on I need to analyze the signals for calculating heart beat and blood oxygen saturation. Anyway, labview doesnt read the data. I have tried to check the connection with hyper terminal and it works properly.
The bluetooth which i am using has been used before with labview, so apparently labview supports it. I have checked all my port settings, baud rate and stop bits, everything is fine. First I was getting this error 1073807360 which is listed as unknown error and now I dunno how it is fixed and I am getting error 1073807339 during the whole program. I read something in the knowledge base about putting a time out value before reading, so i did and now I am not getting the error right in the begining but abit later I get it anyway. I would be grateful if you could check my program and see whats wrong. I have also attached the c code I am using for sending the data which is compiled in image craft.
