Labview program for Anton paar MKT 50
I have an Anton Paar MKT 50  Millikelvin thermometer and an common RS 232 and RS232 USB connector with me.
I could not get any driver software so as to make it run in labview 2010.
Could any1 please help me out with this.
I jus need the program to get the temperature value out of the device to display in my computer sceen.
Also need a refresh rate of about 1 sec.
Please help me with this.
Thanks in advance.
Grugh Mike
Success is Everything !!
(3,533 Views)
Sounds pretty simple. Have you tried using any of the serial examples that come with LabVIEW? Have you tried the Instrument I/O Assistant? Have you tried communicating in MAX or with a standard terminal emulation program such as Hyperterminal?
(3,532 Views)
Anyone has a driver for Anton paar MKT 50?
George Zou
(1,720 Views)
Look here:
http://www.isotech.info/software/labview/
The MKT 50 from Anton Paar is identical to the TTI - 22 from ISOTECH ...
Peter Sinn
(1,640 Views)
