Labview 8.2 with Polyscience Circulator Bath
I'm completely new to Labview and don't know where to begin.  I have been reading the manual and the forum discussions and I am still a little fuzzy on where to begin.  I want to be able to control a Polyscience recirculator bath which I have connected through an RS232 connection.  I think have the the connection set up properly.  I was hoping maybe someone had a template for this that I could use?  Or at least point me in the right direction?
thanks
(4,458 Views)
Hi
the way to handle serial instruments is:
first check idnet
http://www.ni.com/devzone/idnet/
if they have a driver available.
If not then check with the manual of the instrument and hyperterminal if there is some communication
If so try to write a driver or ask help if you are new to labview
greetings from the Netherlands
(4,457 Views)
The instrument came with a driver which I have installed.  I just wasn't sure how to set up the VI to control the instrument.  Thanks for your help.
(4,449 Views)
Hi
If you need more specific help, you can always ask.
(4,439 Views)
