LabView VISA, Tiepie HP3
I would like to ask if you can communicate with Tiepie HP3 through VISA?
And if so, how?
I deleted its original USB drive, installed the VISA driver, and was able to recognize it.But no data could be collected.I wonder if I'm doing it the wrong way.How should Labview be combined with Tiepie HP3?Which documents should I see?I need some examples urgently
(2,384 Views)
Accepted by topic author johnalex114
Hi
Start reading on the Library SDK of TIEPIE here https://www.tiepie.com/en/libtiepie-sdk
And then use one of the interfaces specified to build a LabVIEW API.
Easiest is the C++ or Python lib to use.
Or wait for somebody who already finished this.
Or use the TIEPIE software to gather the data and use the
TiePie_engineering_TPS_Files DataPlugin found on the third party driver site from NI
https://www.ni.com/example/28006/en/
greetings from the Netherlands
(2,361 Views)
