Keysight M9183A DMM
Has anyone already controlled this DMM with LabVIEW ?
I'm using the "Agilent M918x.lvlib" driver which ships with the DMM but it doesn't allow to communicate simultaneously with several instruments.
Many thanks in advance for any advice.
(3,214 Views)
No one has used this DMM with LV ?
(3,162 Views)
Hi
sorry for the late response.
I have a pair of Keysight 9183A installed on a NI PXI chassis (big mistake : I will never mix again hardwares..., you need Agilent IO libraries together with NI). I can not use both M9183 at the same time, even if I put parallel loops in NI...and I have now trouble in accessing them right now... Not far from replacing them with NI though
good luck
(2,480 Views)
