05-28-2015 04:06 AM - edited 05-28-2015 04:09 AM
Hi guys!
I've problems with my new DMM Keysight 34465A. I'm not able to do measurements or anything else with LabVIEW (14 SP1).
Until now, i have some Agilent/Keysight DMMs, but all of them are "older" types, communicating by VISA. The 34465 driver is now with IVI. So this are my first steps with ivi - but i read some tutorials (http://www.ni.com/tutorial/4594/en/ ,....) and i think, that i should get it done... But i didn't geht it done in the last two days.
When i start the "Single Point Measurment "example VI with LabVIEW i get error -1074003951 Primary Error: (HEX 0xBFFC0011) Identification query failed.
When i set the "ID Query" from the Initialisize VI to false, i geht error -1074135024 Primary Error: (HEX 0xBFFA0010) Invalid value for parameter or property. Elaboration: The model specified is not valid.
So I'm not sure if there is a problem in my ivi configuration or a problem with the triver?! Or something else...
Please for help and sorry for my english 😉
edit: The *IDN?\n command is working:
1: Write Operation (*IDN?\n)
Return Count: 6 bytes
2: Read Operation
Return Count: 72 bytes
Keysight\sTechnologies,34465A,MY54500397,A.02.06-02.37-02.06-
00.48-02-01\n
05-28-2015 09:00 AM
05-28-2015 05:37 PM
What version of the installer do you have? Did you check your settings in MAX?
05-29-2015 12:28 AM
You are right, i should use the ivi class triver for my programm. But because of my problems i also tryed to use the 3446x driver.
There is a driver for the 34465A (but model support for 34465A not tested) -> http://sine.ni.com/apps/utf8/niid_web_display.download_page?p_id_guid=E1C5CF089F15079AE0440021287E65...
When i use the ivi class driver i get the same error as i'm using the other driver...
@ Dennis: I'm not shure how to modify the code? (I do not have CVI)
@jjp377: What installer do you mean?
05-29-2015 02:33 AM
05-29-2015 02:45 AM
I downloaded it a few days ago. (After the last update)
So you also think that there is a problem with the driver...
I'm in contact with NI in Munich now, hopefully they can help me!
05-29-2015 03:01 AM
05-29-2015 03:25 AM
I did it now:
1 & 2: ID Query set False
3 & 4: ID Query set True
05-29-2015 03:44 AM
I set "Range" in the "ag 34465x Configure Mesurement" VI to 0.
Same Error, other outcome in the IO Trace
05-29-2015 08:03 AM
Hi pdengg,
can you try to use another name. please keep the syntax as it is default and do not use space in the logical name.
