Keithley 3706 communication with 3730 ST card
Can you elaborate on what you mean when you say "...get all the readings together." I believe that you want to keep all the reading in one place, and in that case, you will want to use a buffer to store your measurements. More help is available on Keithley's forums from one of our dedicated applications engineers.
Message 11 of 14
(1,260 Views)
What I meant was to get the readings of multiple channels at one time; my front panel will have a list of readings where each one of them represent different channels measurement.
In addition, may I asked for the 4-wire ohm measurement, is there a way to vary the voltage (sense input) value as for now, it is automated by the multimeter?
Message 12 of 14
(1,255 Views)
Hello
Regarding multiple channel measurement using 3706.
Did you get to know how to measure from multiple channels at a time?
Thank you
Amith Kashyap
Message 13 of 14
(745 Views)
Hello
Regarding multiple channel measurement using 3706. Did you get to know how to measure from multiple channels at a time?
Thank you
Amith Kashyap
Message 14 of 14
(745 Views)
