Keithley 3706 communication with 3730 ST card
I'm currently using 3706 multimeter with 3730 ST switch card in slot 1. I have connected the multimeter and my desktop through VISA. At the same time i used the keithley driver.
Under the examples, I'm able to do measurements for 'simple measurements' example, however for the 'switching slots' example, i encountered error showing 'Error -1074003951 occurred at an unidentified location' and the possible reason reads ' Keithley 37xx Initialize
The ID Query failed.  This may mean that you selected the wrong instrument or your instrument did not respond.  You may also be using a model that is not officially supported by this driver.  If you are sure that you have selected the correct instrument and it is responding, try disabling the ID Query.'
I would like to ask if there are any reasons for the error such as the wrong placing of the switch panel 3730-ST into the wrong slot or other communication error? Hope someone could clarify my problem.
Message 1 of 14
(5,370 Views)
That example is not meant to be used with real cards. It works fine when no cards are in the system.
Ed
Message 2 of 14
(5,356 Views)
I see. In that case is there any examples that are catered with cards installed into the slot?
Message 3 of 14
(5,348 Views)
What exactly are you trying to do? Are you just trying to close channels, or are you trying to close channels and take a meaurement? It's kinda hard to tell what you want to do with the matrix cards because they are so flexible!
Message 4 of 14
(5,340 Views)
Here is an example that may help you close channels.
Message 5 of 14
(5,337 Views)
Hi, I'm trying to use multiple channels to measure the voltage level of different test probes and save it into the computer which i guess is the buffer?
Message 6 of 14
(5,334 Views)
Say for instance, you hook 6 DUTs (Device Under Test) to colums 1 to colums 6 with the intent to measure the voltage across the high and low terminals: Use the included Simple Measure.vi and you just need to loop through your channels and store the data in a LabView array, no need to use buffers.
Message 7 of 14
(5,330 Views)
Hi, thanks alot for the VIs. It's really useful.
However, I do not know why I'm getting overflow error when I try to measure the 2-wire ohm measurements. I'm quite sure it is due to connections on the 3730 ST card but i tried testingdifferent methods of connection but to no avail. Is there any way you can teach me the connections on the ST card; say to measure a resistor using the 2-wire or 4-wire function.
Message 8 of 14
(5,317 Views)
Accepted by khiam
I unfortunately do not have the bandwidth to help debug this problem. I recommend you post the problem on our forum, and one of our application engineers can qucikly assist you.
http://forum.keithley.com/phpBB3/index.php
Ed
Message 9 of 14
(5,303 Views)
Hi, thanks for the link. Everything is working now:)
Then again, if i wanted to measure 6 DUTs and get all the readings together. How can I do it?
Message 10 of 14
(5,286 Views)
