Je cherche driver du Marconi 2024 utilisable sous la version 6.0 et non pas sous la 6.1
Bonjour,
Je travaille actuellement sous labview version 6.0. Dans mon programme j'utilise un Générateur HF Marconi 2024 et les seuls drivers disponible fonctionnent sous la version 6.1 et donc ne fonctionne pas sous la version 6.0 je n'est pas de solution
Merci
(3,024 Views)
Hello Denzel,
Unfortunately, NI does not have a LV driver for the IFR/Marconi 2024. However, there is an available CVI driver for the model. It is possible to use this driver with LabVIEW if you use the "Import CVI Instrument Driver" utility found within LabVIEW (from Tools -> Instrumentation -> Import CVI Instrument Driver). Please note, however, that this utility is a quick fix and will create a functional driver, but the driver will not exactly be "beautified."
If you choose to try this approach, the CVI driver can be found on our website at http://zone.ni.com/idnet97.nsf/browse/; then fill in the search options as:
Manufacturer: Marconi Instr. (IFR)
Additional Key Words: 2024
Instrument Type: Sources
Development Environment: LabWindows
/CVI
Driver Type: Plug and Play
Interface: GPIB
If you have any questions or run into any problems with this process, please email instrument.driver@ni.com.
Best Regards,
Katie Rollo
Instrument Drivers/IVI
(3,024 Views)
