Is there a simple GPIB C++ example for Visual Studio 2005?
Howdy,
I'm looking for a simple example to open a handle to an instrument, write a string to it, and receive a string from it -- nothing fancy, just the basics.  Sounds simple, but it's proven difficult to find.
I'm porting my code over to C++ in MS Visual Studio 2005 and simply looking for an example which will read and write strings to a device over GPIB.  All of the code examples and message posts I've found relate to using Measurement Studio, which I do not have and am not interested in purchasing.
Chris
(10,064 Views)
Have you looked at the examples that ship with VISA, or the NI-488 driver? Those are your best bet. The VISA examples are installed by default in "C:\VXIPNP\WinNT\NIvisa\Examples\C". The one you probably want to look at is the "RdWrt" in the "General" folder. The ones that come with NI-488 don't use VISA, and are installed by default in "C:\Program Files\National Instruments\NI-488.2\Languages".
(10,042 Views)
Chris,
Thank you for contacting National Instruments.
If you are using a Windows XP system, there are many shipping examples. I was able to find a general GPIB read/write C++ example at the following location: C:\Documents and Settings\All Users\Documents\National Instruments\NI-488.2\Languages\MStudioVC2005\Basic Gpib. The example is BasicGpibDlg.cpp.
Please let me know if you are unable to find this example. Hope this is able to get you started.
Have a great day.
Sarah S.
Applications Engineering
(10,042 Views)
Thanks, smercurio_fc and Sarah_S, this is exactly what I needed.
My major complaint with complex systems, such as NI T&M products, is that it's not always obvious where to get started.  Add that to the complexity of MS programming enviroments, and it's sometimes daunting!  I'm an RF engineer who still wishes I could write everything in good 'ol ANSI C...
These examples are a key starting point.  I'm surprised they were not called out in the NI Instrument Control Fundamentals tutorials.
Chris
(10,031 Views)
I'm not finding this sample code in the mentioned location and I want to connect to my GPIB-USB with c++. Can anyone help me with that?
(6,171 Views)
Try pasting the file path mentioned above in your file explorer.
The Documents and Settings folder is sometimes hidden so see if you can access it that way.
(6,156 Views)
Thanks for your response.
Here is what I have:
C:\Users\Public\Documents\National Instruments\NI-488.2\Examples
I don't have "Languages\MStudioVC2005" and in the examples there is no file or directory  as MStudioVC2005.
I want to be able to write into GPIB connector with my c++ code. Is there any other place I can look for the file?
Thanks.
(6,149 Views)
