Is there a LabView6 driver for Thermotron S-8-7800?
Does anyone have a LabView6 driver for Thermotron S-8-7800? I'm using LabView6, TestStand, and MS Window NT4.
(3,505 Views)
Hi Jimmy,
I was able to find a Thermotron 7800 instrument driver for CVI by going to http://zone.ni.com/idnet97.nsf/browse/
and searching for Thermotron. You may be able to use that in LabVIEW using the "CVI Function Panel Converter". You will find this option in LabVIEW under Tools>>Instrumentation>>CVI>>Import CVI Instrument Driver. You can find out more about this feature by searching LabVIEW help for CVI or by going to:
http://www.ni.com/support/cvi/visa/
All LabWindows/CVI .dll files require run-time support. You must install the LabWindows/CVI Run-time Engine to use VIs that the conversion process creates. This engine comes as part of the standard LabVIEW installation.
Please contact National Instruments if you have questions.
Kim L.
Appli
cations Engineer
(3,505 Views)
