I have a minor issue with one of my instruments that i control with labview. I can control it via Serial or GPIB control. When i load up my vi for the first time and my instrument is set to GPIB address 1 there is a slight delay loading up the program and I get an error light on my instrument. This means some info is being sent on the GPIB bus. After the slight delay the program finishes loading and the error light goes off telling me something else was sent to my instrument. This error occurs ONLY when my instrument is set to address 1. Any other address and everything works as expected. To combat this error in my vi i just send a *cls to clear everthing before i write again because the error seems
to send something that will mess up my first sent command. I ran NI spy to see what is happening when i load my VI's.
This is what NI SPY shows labview is doing on the GPIB card when i load up my VIs
1. viOpenDefaultRM (0x00154348)
2. viGetAttribute (0x00154348, 0x3fff018f, VI_TRUE)
3 viGetAttribute (0x00154348, 0x3fff0190,2 (0x0))
4 viSetAttribute (0x00154348, 0x3fff0190,2 (0x0))
5 viFindRsrc (0x00154348, "?*INSTR", 0x00157108,3 (0x3), "COM1")
6 viFindnext (0x00157108, "LPT1")
7 viFindNext (0x00157108, "GPIB0::1::INSTR")
8 viClose (0x00157108)
9 viSetAttribute (0x00154348, 0x3FF0190,0 (0x0)
Step 5 is where i get the error and labview hangs for a second. After it passes my error light goes off and it will continue to load. This issue only occurs when i have my instrument set to GPIB address 1. There seems to be some kind of conflict that occurs. Could it possibly be the software used in the instrument?
