Instrument Drivers for HP(Agilent/Keysight) 83711A/B
Hello Everyone,
I'm looking for inst. driver for HP 83711a. It's synthesized CW generator of HP (Agilent).
I find everywhere and couldn't find. I would appreciate it if anyone can assist with it.
Thanks in advance.
(2,483 Views)
https://www.keysight.com/main/software.jspx?ckey=1000000679%3Aepsg%3Asud&lc=dut&cc=NL&nid=-32468.536...
83711B, 83712B, 83731B, 83732B Signal Generator VXI Plug and Play Driver
The VXIplug&play driver for 83711B and 83712B Synthesized CW Generators and 83731B and 83732B Synthesized Signal Generators. Programming with this driver does not depend upon an I/O library specific to your brand of HP-IB/GPIB interface, thus your programming code becomes much more portable. The Visual Basic and Visual C++/Borland C++ Programming Examples using this driver are built-in to the Windows Help file for the driver. The driver is compatible with all of the following programming environments:
  • Microsoft Visual Basic Version 4.0 or higher
  • Microsoft Visual C++ Version 4.0 or higher
  • Borland C++ Version 4.5 or higher
  • HP VEE Version 3.2 or higher
  • National Instruments LabWindows/CVI Version 4.0.1 or higher
  • National Instruments LabVIEW Version 4.0.1 or higher
greetings from the Netherlands
(2,473 Views)
I found this one: http://sine.ni.com/apps/utf8/niid_web_display.download_page?p_id_guid=E3B19B3E9702659CE034080020E748...
GCentral
(2,472 Views)
That one looks better
crazy finding in ni.com again.
(2,455 Views)
Hi Albert Geven,
Thank you for your fast response.
I found that link earlier too but I'm using windows 10 and unfortunately I couldn't install it.
(2,443 Views)
Hi Crossrulz,
Thank you for ur fast reply.
I found that file too but hwo can I include to the functions palette>> instrument I/O>> instr drivers>> instrument drivers>> ??
(2,441 Views)
@AwAU20 wrote:
Hi Crossrulz,
Just put the contents in of the zip file (ie. the folder that is inside of the zip file) in <instr.lib>.  Then restart LabVIEW.
GCentral
(2,422 Views)
