Install real time software on sbrio9606
I have the new sbrio9606 which has nothing installed on it. On powering the sbrio, i can see the yellow LED blinking twice, which indicates me to install the real time software and others.
But the sbrio is not seen in my NI-MAX and tried to trouble shoot it and it do not discover the device. If i try to check the device's IP in cmd, it do not show anything. But i can see the LED blink on the RJ45 connector. I have LV15 and all other software installed on my machine and able to program the sbrio which has the RT installed on it. So, i think my HOST machine is all good.
I have tried troubleshoot option in MI-Max, and it ends up not discovering it.
Can anyone help me in how to bring up the new sbrio9606.
Yogesh
(2,767 Views)
Hi YogeshaYS,
It looks like you have posted this question in the Instrument Control forums, that is likely why you haven't got a reply until mine. I would repost this question in the RIO forums to get an expedited answer.
Have you had a chance to review the knowledge base article covering this topic? In the additional steps section, it talks about some network connectivity troubleshooting steps to try. Since you have another sbRIO you can see and deploy to, I agree the software stack on the Host PC is probably fine.
I would try connecting the unknown sbRIO through the same ethernet port your working one is connected to and disable WiFi on your host if applicable.
Jacob C.
Applications Engineering
(2,726 Views)
