12-10-2008 04:25 PM
Hello
I try to run the Visual Basic Demo Example that is located in Start>>All Programs>>IVI TekScope Driver>>Sample_Projects>>Visual_Basic_Project
in order to command the TDS2024B and works fine with for the Aquisition paramentes and Vertical settings but when I press the Fetch Waveform button I receive an the following Error:
Error:TekScope: Failure- cannot recover
Error Code: bfff0015 1000440
Is the TekScope_TektronixLib fully compatible with the TDS2024B?
Thanks for your help.
12-24-2008 10:25 AM
Hi Delt;
As I understand you are using Visual Basic, but what other software are you using, LabVIEW, LabWindows CVI, etc. That information could help a lot to understand your problem. For instance, just in case it is a driver problem, here's a link to your oscilloscope drivers supported by NI.
http://sine.ni.com/apps/utf8/niid_web_display.model_page?p_model_id=9081
Good Luck
Francisco Arellano.
