IRIG timestamp translator for use with GPIB or VXI?
Thanks in advance for looking at my question,
I have a control system consisting of a VXI mainframe, GPIB bus, and a laptop running Labview that I need to loosely synch up with another system.  The technicians are able to provide an IRIG signal, but so far I am baffled as to how I will convert it into something usefull  (I don't think I have the overhead to decode IRIG on the fly with a analog input).
In my mind I'm looking for an:
IRIG receiver that is gpib equipped,
a VXI card that acts as an IRIG decoder,
or a PCMCIA card acts as an IRIG decoder.
Any suggestions?
IRIG is so common, I have to be making this harder than it is, right?
Thanks again...
(3,990 Views)
drfunk,
To decode IRIG-B, we offer the NI PXI-6608. This device allows you to perform either software or hardware timestamping. In software timestamping, a function call returns the current value of the IRIG-B signal. In hardware timestamping, a clock (or some other TTL signal) causes the current timestamp to be buffered for later software reads. There are 2 such decoders on the 6608, allowing you to timestamp 2 TTL signals with the same IRIG-B source, or to have 2 independent IRIG-B sources. I would use the 6608 in a PXI chassis with a VXI to PXI, MXI-2 bridge.
Hope this helps,
Ryan Verret
Product Marketing Engineer
Signal Generators
(3,971 Views)
Thanks for the reply,
That is a solution, albeit a prohibitively complicated and expensive one.
The closest thing I've found to a simple VXI solution is from a 3rd party vendor:
http://www.symmttm.com/products_blt_bc635-350.asp
it also seems like many mil-spec-1553 cards often come with IRIG translators.
Still looking for a cheap and dirty solution though...
(3,960 Views)
