08-16-2007 05:22 AM
08-17-2007 05:51 AM
08-04-2010 10:45 AM
"What I have found out is that you need to use "space \r space \n" as the termination character."
Well done, it's written at the manual. 😉
01-05-2011 09:09 PM
Giuseppe999--
Did you ever write a VI to control the IKA Eurostar lab mixer? I recently purchased one also and am interested in controlling it with LabView.
01-06-2011 02:34 AM
Hi, yes I did in the end - it turned out to be very simple, we went on to build complete automated rigs with pumps, valves, mixers etc in labview (even a robot on another project). Drop me your email and if I can find it I'll get it across.
11-30-2011 08:21 AM
I purchased an IKA Power control visc P1 but can't find a good VISA to control the device with LabView. Can you help me with that? Besides, what are all the numbers I should write in the VISA control panel parameters?
Thank you, gerard
11-30-2011 08:24 AM
Thank you, gerard
02-14-2012 02:17 PM
I'm also trying to interface with the IKA RET, and am having trouble communicating to the device.
Where those of you that successfully connected to the IKA, did you use a standard serial cable or the proprietary cable made by IKA?
04-23-2012 04:40 AM
Hi!
I am really stuck and would need and greatly appriciate some help. I am also trying to connect my PC to the IKA Eurostar stirrer and I am having some problems. When trying to run my the VISA I get the message that the device is valid but can not be accessed. Have any of you had this problem and if so hoe have you solved it.
Does anyone have a VISA for this application. I really only want to be able to read the output signal.
regards /Suss
PS. The error message I get looks like this, if it is of any help.
Error -1073807246 occurred at Property Node (arg 1) in VISA Configure Serial Port (Instr).vi->stirrer.vi
Possible reason(s):
VISA: (Hex 0xBFFF0072) The resource is valid, but VISA cannot currently access it.
04-23-2012 05:09 AM
Hi!!!
Sorry for my delay in replying. Unfortunately I didnt find any VI that worked for the stirrer. As i had to programm other things I just put the programming of the control-visc P1 from IKA on one side. Did you fix this problem? Do you have any VI that really works? I only need to change the rpm...
Thanks, gerard
