IDN? returns almost right answer
Currently trying to control a Keithley 2182A NI input/output interface.
The usual python script that controls the system failed. After checking rom the NI input/output panel I found that the instruments spits out "almost right" answers.
when asked for voltage would respond with special characters and even the IDN command seems to fail, see below:
query : "*IDN?"
out : "KEIDHLEI\sINCDBEMENDC\sINC.,MODEL\s"!("A,$$)\s"'&,C\s(/B\s!\s\s\n"
Changing the view type does not fix the issue.
Looks like this could be an encoding issue, however I could not find other posts with a similar issue.
Thanks in advance for the help.
Best,
Ulderico Filippozzi
(1,202 Views)
What bus are you using to communicate with this instrument?  It looks like this device could be RS-232 or GPIB (IEEE-488.2).
Your error seems related to have a bad GPIB connection, usually caused by too long of cables.
(1,197 Views)
