12-09-2011 08:38 AM
Hello all,
I have tried searching the forums for similar issues but no luck, So here is my issue
Language = VB6
GPIB interface = USB
Instrument type = NI 7265 lockin amplifier
Most of the communication involved is a simple send command (IBWRT) and then serial poll waiting for data ready signal, and this works great, all the commands return single line strings.
I am now trying to use a command to query the firmware revision of the lockin (REV) which the manual states responds with a 4 line reponse, hwoever the serial poll never gets to decimal 128 to show that data is ready, it simply shows a command complete status (decimal 1, which appears to be from the previous command)
the code i use is below
Public Function LiRead_Data(Call_string)
askString = Call_string + Chr(13) 'CR terminated string required
Call ibwrt(devAssign, askString)
SPSB = 0
While SPSB = 0 ' This just loops if the instrument is busy
Call ibrsp(devAssign, SPSB) ' devAssign is previously associated with the lockin
If SPSB >= 128 Then ' data is ready go read it
b = Space$(32) ' in theory this should be ibcnt (which is updated at each serial poll)
Call ibrd(devAssign, b) ' read available data
LiRead_Data = Left(b, ibcnt) ' trim data set the function return
End If
Wend
There is some error trapping code also but none of that gets triggered as SPSB is always 1 (command completed)
When i use any of the other lockin functions that return a single line reponse - the process occurs as i expected, there may be a few loops while the SPSB is still zero as the instrument sorts itself out but after a loop or two it returns the expected result. this can be seen on the comms test menu on the instrument
however when i send a REV command that the device manual says "returns a 4 line response which the receiving program must be able to accept", the SPSB goes straight to a 1 - never indicating that there is any data there to read. However on the comms menu of the instrument it clearly shows 4 seperate lines of data seperated by <CR><LF> characters.
I was expecting to maybe receive the first line if some where in the code it terminated at the first <CR><LF> characters, but as far as i can tell no data ever becomes available.
So the question is have i understood the principal of the serial polling sufficiently that what i think should be happening is, or is it somethig i have missed.
I have monitored ibcnt and this shows no data available also.
any help would be appreciated.
Justin
12-09-2011 11:44 AM
I Should say that the REV command is pretty trivial, but there are other multiline commands that i will need to use in the future, and this one seemed an easier one to start with. I just want to ensure that i have understood the process correctly for using the serial Poll.
