Install NI-488.2M software for Win95. As I remember there must be
a switch (checkbox) in the Control Panel | System | Gpib, which
will enable DOS support in the virtual DOS machine.
eb
"Amit" wrote in message
news:506500000008000000C11E0000-986697009000@quiq.com...
> I have a AT-GPIB/TNT board on my computer. I am using the NI488.2
> software for DOS. I am running this on a Windows 95 platform in DOS.
> Right now I am checking the software to test the hardware and the
> software. When I run ibdiag it first detects one board and then I get
> errors saying :
> 1. Make sure the GPIB cables are disconnected.
> 2. The base address does not match the address in the ni-pnp.ini file.
> 3. Another board or device is using the same address space. Try using
> a diff
erent I/O address and run the hardware diagnostic program.
> For error # 1 I ensured that GPIB cables are disconnected. I dont'
> know what to do about error # 2 and 3. I have been using the same
> software and the board in the previous machine which was DOS based and
> it gave me no problems. I have only one board in the machine. I tried
> changing the base address in the ibconf utility also but it didnt'
> help.
> When I try to run ibtest it hangs in between .
> ni-pnp.exe is running without any problems.
> gpibinfo is also running without any problems.
> With this info please let me know where the error could be .
