I am not able to get data at DIO[0-7] of NAT 9914
I am following the steps of AN 110 & Chapter 5 of Reference manual.
But not getting the data at DIO[0-7] on the NAT 9914
my test 5 is as following
 AUXMR();                //For selecting AUXMR Register
 wait(125000);
 MODE9914();          //To Set 9914 mode
 wait(125000);
 AUXCR();                //For selecting AUXCR Register
 wait(125000);
 LOCALPONASSERT();        //For asserting Local Pon
 wait(125000);
 SOFTWARERST();         //Software Reset
 wait(125000);
 wait(125000);
 SETCLK();          //For setting ICR
 wait(125000);
 wait(125000);
 MODE7210();          //For mode 7210
 wait(125000);
 AUXMR();                //For selecting AUXCR Register
 wait(125000);
 PAGEIN7210();         //Page in command in 7210 for MICR
 wait(125000);
 MICRSET();          //MICR bit set
 wait(125000);
 wait(125000);
 wait(125000);
 ADDRESS();          //To Set Address
 wait(125000);
 SETT1();          //To Set Delay T1 of GPIB
 wait(125000);
 LOCALPONUNASSERT();        //For Unasserting Local Pon
 /*       FOR TEST 5        */
 PAGEIN9914();         //Page in command for IMR 2
 wait(125000);
 CLRIMR0();          //Clear IMR 0
 wait(125000);
 CLRIMR1();          //Clear IMR 1
 wait(125000);
 CLRIMR2();          //Clear IMR 2
 wait(125000);
 SETton();          //Set Talker only
 wait(125000);
 CDOR();           //select CDOR register
 wait(125000);
 RDCPTR();          //Read CPTR for checking data at CDOR
 wait(125000);
 ADDRESS2();          //Set TAD in ADR to disable talker
 wait(125000);
 RDCPTR2();          //Read CPTR with TAD
 wait(125000);
 ADDRESS();
(3,587 Views)
What values are you getting when reading from cptr?  How does this compare with what is being written?  Do the other tests work correctly?
Steven T.
(3,561 Views)
Thanks for reply!
I have connected my contoller ARM7 pins of D[0-7] via 74LVC245A & it's DIR is connected to logic high so,i can transfer the voltage from controller to NAT 9914BPD & not revert it.
So i am going for these test first.
The comparison is actually not done,
So i will like to know how should we compare it?
Actually i am trying to check data at DIO[0-7] by writing to CDOR but it is having no change (all are at 4.96v) &
I am also writing to BCR for setting & reseting to DAV,but it is also unaffected(4.96).
I have connected ACCGR to +5v.
Is any other change required.
Thank you in advance for reply!!
(3,510 Views)
I am interfacing the ARM7 uC & the NAT 9914 ,for D 0-7 is provided via 3.3-5V converter.
The CE,WE Dbin & the RS0-2 is provided directly to the NAT 9914.
I am following the sequence
For setting the
1.RS0-2
Then pulling the CE.
then Pulling the WE (in write cycle)
Then placing the data in D0-7 as provided in the timing dia in the NAT 9914's datasheet.
I have reffered to the reference manual,Datasheet & AN110.
I am follwing all the steps for initialization i have attached my hardware schematic & the program (in Embedded C).
You can run the program in keiluVision 3.
Tell me if any more pins need the buffer in the hardware.
Tell me if i am missing any steps.
When I am trying to read the RDISR0
I am strucked at this point so tell me if i am doing any mistake
I am attaching the Hardwarre schematic & the Program in txt format.
(3,271 Views)
