I'm thinking about the concept how to conncet the devices with the computer to do the test. If you guys coud comment and give any hint that would be great.
The main problem is: How to talk to one device from two controllers?
I have to communicate with the DEV3 from the MAIN HOST and DEV0. However, the devices are conncted amongst them thru different media (GPIB and USB).
It wouldn't be a problem if my connection look like below:
In this case the topology B (B1 B2 B3 and BC) would have two controllers which is completly fine.
However, my topology is hybrid and looks like below. For reminding, I need to communicate with DEV3 from DEV0 and the main host.
My questions:
1. Is it ok to connect USB port on MAIN HOST with the USB port on DEV0 (with the connection BC2) and doing so connect to the topology B with the second controller? It would work with GPIB connections only as I've shown on the first picture.
2. Do you have maybe any other concept how to do this?
BTW: Please forget about the BC1 connection shown on figure 2. It is bit misleading to have this connection BC1 drawn on the picture 2. Phisically it won't be present.
Many thanks,
K.
