04-12-2012 01:38 AM
Hi all,
I'm a beginner in Labview programming and I need some help on creating this interface control.
Attached is the program and a jpeg of the frontpanel.
I would like to use the "next" button to control the next sequence of entring the parameters(ie fm/am, Mhz,dBm etc.) and aquisition of SINAD.
This means that only when the user presses "next" then the next frequency parameters will be entered and SINAD measured.
I hope someone out there understands what I mean and would be able to help me on this. I cant seem to get the attachments to work together with this post.
04-12-2012 07:56 AM
Please, please, please read this: Application Design Patterns: State Machines
and stop relying on sequence structures so much.
04-12-2012 08:21 PM
Thanks for the quick response, but I need each frequency with its other settings to flow in a specific order with just the "next" button to control when the user wants to change to the next frequency step. Is state machine still able to achieve these results?
I know my program is too simple thats because i'm really a beginner who just started learning labview using a guidebook.
Really appreciate all your help!
04-16-2012 08:40 PM
Hi, I manage to utilise the use of state machines already, however, it does not solve my problem of using one same "next" button to switch to the next state. I tried using local varables but it is not allowed in the event structure, are there any other alternatives?
04-17-2012 07:41 AM
You must not have implemented it correctly. Please post your latest code.
