How to open VISA session, Set GPIB / I.P. address in C#, working with .NET Interop assembly DLL?
Hi.
I generated .NET Interop assembly DLL from LabView 2012 and have to use it in C#.
DLL - is from Agilent 34401A labview driver.
.NET Iterop assembly wizard generated Initialize function like this:
 public static void Initialize(LVReferenceNumber VISA_32resource_32name, bool ID_32Query_32_40True_41, bool Reset_32_40True_41, out LVReferenceNumber VISA_32resource_32name_32out);
What should I write in my C# test to set GPIB / I.P. addres? from Labview or MAX my DMM is acessible using address: GPIB0::22::INSTR.
Also, I have to generate DLL to scope and have to use I.P. address to open VISA.
I understand that I have to set some value to variiable:
BUT, don't know exactly how to do it.
Can you help me?
Message 1 of 19
(9,132 Views)
I don't know why you went to all of the trouble to do this when you can easily use the IVI driver for this instrument.
Message 2 of 19
(9,118 Views)
Because I downloaded instrument driver from NI.com as Labview project with descrete VIs. And every VI has VISA in and VISA out. My question is how to create variable in C# that will hold VISA address - GPIB0::22:INSTR   for example or I.P. address if needed.
Message 3 of 19
(9,077 Views)
Again, why are you using LabVIEW driver when your programming language is C#.
It makes NO sense.
If you are using NI hardware, look at the programming examples that should have been installed on your PC.
Message 4 of 19
(9,061 Views)
I'm using Agilent, Tectronics, BertScope and Holzworth hardware.
standard instrument drivers from NI - labview VI.
Also, for new custom made instruments all what I get from manufacture is set of GPIB commands and maximum what i canask is to have labview VIs.
This is the reason.
And usage of .NET Interop assemble DLL in C# is standard procedure.
All what i need is to understand how to set VISA ...
Message 5 of 19
(9,047 Views)
This is the reason.
And as I wrote above, look at the programing examples that was installed on your PC by NI.
Message 6 of 19
(9,029 Views)
NYC.
Will you be so kind to give me a link to this manual (I failed to find it ...), assuming that LV installation path is standard istead of saying RTFM? Thanks in advance.
Message 7 of 19
(9,023 Views)
It is not in a manual. The links to the examples should be under the National Instruments NI-VISA in the Windows Start Menu
You may need to go back and install NI-VISA if you did not include the support for .NET Framework during the installation.
Message 8 of 19
(9,018 Views)
I'm also having trouble understanding what you are doing. You just mentioned a LabVIEW manual when you should be looking at the VISA programming examples.
I don't understand why you would request a LabVIEW driver from a vendor when IVI-C or IVI-.NET would be more appropriate.
A VISA Resource Name can be simply text and the oft mentioned examples should make that clear.
Message 9 of 19
(9,014 Views)
Guys … Thanks for suggestion, but please understand that someone who started programming in LabView 6.0 knows why his question came to this forum.
I have tons of instrument drivers, written in LabView or just valuable code, which should be used from C#.
For this purpose I have to use .NET Interop Assembly. Or you can suggest better way?
Standard VISA example written in this manner:
using NationalInstruments.NI4882;
private Device device;
device = new Device((int)boardIdNumericUpDown.Value,(byte)primaryAddressNumericUpDown.Value,(byte)currentSecondaryAddress);
device.Write(ReplaceCommonEscapeSequences(stringToWriteTextBox.Text));
BUT, in NI manuals, usage of Interop assembly followed by:
using NationalInstruments.LabVIEW.Interop;
and only after I can use created DLL (with instrument driver):
using DmmAg3440aVer2;
The point is that Initialize VI, which nicely opens VISA session in LabView to this DMM, converted to function like this:
where GPIB address in some way have to be set in function argument:
And I don’t know how to deal with variables from this type.
So,
Try please with all respect try to answer on MY question …
Message 10 of 19
(9,009 Views)
