10-10-2008 09:25 AM
10-16-2008 12:26 PM
Hola Myfamis!
Existen varias formas de lograr lo que comentas. Para una atención personalizada al respecto te recomiendo llames al número gratuito de NI: 018000100793.
Pide te comuniquen con un representante de ventas para que te oriente sobre la mejor solución para tu sistema.
Saludos y que tengas un excelente día!
10-17-2008 03:33 AM
The cheap way:
Use the installed meter from your energy provider. All you need is a pulse out every XX.XX Wh. Modern electronic powermeter provide an LED pulse (easy 😉 ) and even for the classical ferraris meter you can find solutions in the web by monitoring the disc. I have seen a solution with two photosensors in a bridge and a comparator all hooked up and powered by the handshake lines of a RS232.
There should be some ATMEL/PIC solutions in the web (ELV, elector, circuit cellar, g**gle), that will do the monitoring and storing and have a RS232, so your PC doesn't have to run all the time (I assume you want so save energy).
The professional way:
Ask your provider to install a modern business meter with a build in opto coupled serial output. These devices can store a 90/30 day profile 🙂
All the rest can easily be done in LabVIEW ... THINK IT. DRAW IT. RUN IT 😄 😄
10-17-2008 09:29 AM
-Thinking outside the meter box-
Use a camera in a weather proof enclosure with LED illumination for night time focused on the existing meter. Depending on climate, may need heating/cooling.
Use vision tools to pattern match the digits (if it is an LCD display) or capture the clocking of the individual digit needles.
Outside ambient lighting changes throughout the day could be an issue.
No need to change meter, no code violations in attempting to tap into meter signals, and 100% electrical isolation from the power mains.
Just an alternative idea, not sure how practical it may be for your task.
-AK2DM
10-20-2008 01:35 AM
AK2DM,
I never thought about any code violations
All my suggested ways will stick ON the meter, they just omit the camera 😉 and use one or two phototransistors that look at meter.
But in times where simple electronic parts are expensive in low quantities you might be right in spend very little money on a web cam you get everywhere . No need of heating the solder iron ;-(
Here it goes: The software is the instrument 🙂
