How to interface PCI-8433 to Visual Basic 6.0
We have an existing Visual Basic 6.0 application that uses the com port to talk to a serial device. The serial device is being upgraded to a high speed serial device (1.2 Mbps) and we're looking at the PCI-8433 as a possible solution. How do we interface that to the Visual Basic 6.0 Program.
(2,964 Views)
Hi Jonsai,
If you want to integrate your serial device into your  existing application, there is a Visual Basic 6.0 VISA API that is identical to the C VISA API.  You can use the C examples to show how to create a program in Visual Basic 6.0.  There are also a few Visual Basic 6.0 examples in the C:\Documents and Settings\All Users\Documents\National Instruments\NI-VISA\Examples folder.
Caleb W
(2,947 Views)
