How to control two GPIB instruments in one GPIB card?
Dear All...
In my project, I need to control two GPIB Instrument (prober and meter) which connected with the same GPIB Card in my PC.
when I Initial Prober, I get two handles GHostUD_P and  GDevUD_P,
then I Initial Meter, I get two handles GHostUD_M and GDevUD_M,
My Question is  I need to Initial GPIB card twice!? or can only initial once..(use the same GHostUD...)
if I want to Disconnect Prober but still use Meter...
so I use ibonl (GHostUD_P ,0) and ibonl (GDevUD_P, 0) two command, then the gpib card has been set to off line...
Does it effect the Meter's Communication!? if I use different GHostUD handle, dose it work!?
thanks a lot...
(3,619 Views)
Thank you for posting on National Instrument's forum.
What's the model of this GPIB Card?
The purpose of GPIB, is to communicate with several device.
Brice S.
National Instruments France
(3,608 Views)
thank you for your response,
my GPIB card PCI-GPIB NI-488.2
I know GPIB can connect several Instrument, but I don't know how to control the connect/disconnect behavior so two GPIB instrument will not conflict...
so my question is if I disconnect A Instrument use ibonl(host_A,0), ibonl(dev_A,0) command, then B Instrument still connect!?
thk...
(3,583 Views)
Do you want disconnect instruments in MAX or in your VI?
Brice S.
(3,449 Views)
