06-07-2005 09:00 PM
06-08-2005 09:26 AM
07-11-2005 07:45 AM
Hi, I would like to use the Lakeshore 340 TC with the serial interface to read the temperatures of several sensors and to control devices. Can anyone help me? The drivers I could find are only good for use with the IEEE 488.2 interface which I do not have :mansad:
I would appreciate any suggestions! Thanks - Pat
07-11-2005 08:25 AM
07-11-2005 08:43 AM
Thanks a lot for your prompt answer I will try this!
Pat.
07-11-2005 12:13 PM
Hi again Dennis,
I did replace the code for IEEE 488.2 with that for the serial stuff, actually I took all the first part (i.e., "Open Instrument" and " Set Serial Visa Attribues") of the Hp 34401A Initialize.vi block diagram for initializing the LakeShore T.C. which worked fine. Then I wanted to replace the "Initialize Instrument" Section of the "Getting Started Temperature Controller.vi" for the Lakeskore 340, but I received following error messages when I replaced the : "Instr. Descriptor" with the "Visa Resource" and tried to wire it to the "LSCI 340 Initialize"-box: "You have connected two terminals of different types. The type of the sources is VISA sessions of class. The type of the sink is void". What's wrong. I very much would appreciate your help 🙂
Thanks in advance
Pat
07-11-2005 12:30 PM
07-12-2005 03:40 AM
Hi Dennis, hi everybody
I did use the new VISA Open function by taking the first part of the hp 34401A Initialize.vi routine, i.e., I think I successfully changed the Initilaze.vi for my device. But now I have to change the other vi's which actually control the instrument. I have therefore tried to alter the relevant part of the "Getting Started Temp. Contr.vi" for my instrument. It look like this:
07-12-2005 08:37 AM
07-12-2005 12:06 PM
Thanks a lot for your help, Dennis! :manhappy:
I got many features running now, but still the Getting Started.vi has to be changed somehow, because it won't work w/o changes: The old Instr. Descriptor and error in have to be connected to the initialize box somehow, but since the data types have obviously changed, I have to figure out how exactly to do that. Actually I found out that I was having troble with my USB 2.0 --> Serial adapter (Digitus Accessories). I wonder if that is a common issue, maybe someone could give me some feedback for that issue, too.
Bye
Pat_M
