How to configure sampling rate for Tektronix TDS6124C
Hi all
I am using tektronix TDS6124C oscilloscope to monitor the signal at ethernet port
I am unable to configure the Sampling rate and no.of samples for the scope
Kindly can anyone send me an example for configuring the sampling rate.
With regards
Bala
(3,768 Views)
Are you using the driver ? The commands would also be in the manual.
(3,759 Views)
Hi Dennis
Thanks for your reply
Yes i am using the drivers and i am unable to configure.
I am using the examples given with the drivers and if i change the time base in the code it is not reflecting in the scope
If you have any examples kindly send me if possible
With regards
Bala
(3,741 Views)
Hello Bala,
         I have a TDS 5104 at my desk and ran the "Acquire Multiple Waveforms Example" and changing the timebase worked correctly.  Without changing the default value, the scope's screen showed 800 ns/pt, and when I changed the timebase from 0.005 to 0.05, the scopes screen displayed 8.0 us/pt.
Please try that example and only change the timebase the same way that I did and tell us how many s/pt the scope's screen displays.
Cheers,
NathanT
(3,732 Views)
