09-30-2005 10:30 AM
10-03-2005 07:21 PM
10-04-2005 06:12 AM
10-04-2005 11:10 AM
Hi
I've reproduced an error similar to the one that you have by using the LabVIEW IVI driver available on IDNet. I did so by adding a Clear Arb Waveform function call directly after configuring and outputing a user-defined arb. An error returns stating that you can't clear the currently selected Arb from memory. Based upon this, I decided to select one of the built-in arbs (sinc) before clearing my user-defined arb. After making this change, the error disappeared. So in summary, here is what to do once you are ready to clear your user-defined arb (at a high level):
1) Disable/Abort the output (optional)
2) Select a built in waveform, such as Sinc (according to LabVIEW, the handle for the sinc waveform is 10004). The 33220 has 5 built in arb waveforms to choose from, which are described on page 228 of the users manual. Link:
http://cp.literature.agilent.com/litweb/pdf/33220-90002.pdf
3) Call the Clear Arb Waveform function, using the handle for your user-defined waveform(s).
Hope this solves your original problem!
10-05-2005 04:48 PM
10-07-2005 06:24 AM
