How to Display a Signal from an Instrument in a Waveform Graph?
Hi all,
I'm fairly new to LabVIEW and I am creating a HAL to control a spectrum analyser through VISA.
I can control all the settings of the instrument from the HAL, but I want to display the signal that the instrument is showing in a digital waveform graph on the front panel (mirroring the signal that is on the instrument's screen).
I have tried using the Simulate Signal VI but it does not create a signal that looks like the one on the spectrum analyser.
Any help is much appreciated!
(2,801 Views)
Hi there!
Do you think you could share a bit more of details on what you are trying to accomplish? Sharing a simple version of your code and maybe an image of what you would like to get would be useful.
I am a bit confused on whether you are getting a digital or an analog signal from the device, Are you receiving a spectrum or a digital pulses train? If your goal is to show a signal similar to what is shown in the instrument's screen, we should probably get the data you are receiving from the instrument and display it directly instead of simulating a separated signal. Are you being able to receive data points from the device already?
WenR
(2,731 Views)
