05-09-2006 06:20 AM
05-09-2006 09:11 AM
05-10-2006 06:35 AM
Thanks alot for Collin M's help.
I check in Tektronix's web, and can only find TEKTRONIX TEKSCOPE IVI-COM DRIVER V2.0 (13.9MB). I can not find subvi or lib file.
If I want to run the VI with the LABView on oscilloscope, shall I first install this oscillocope's driver?
Do you have a tutorial or example for LABView to do this job?
05-10-2006 07:50 AM
11-13-2019 02:57 AM
Dear Collin M,
I am also planning to do the similar application, we have Teledyne lecroy oscilloscope with WIN 10, I want to remove the PC from our test set-up and connect all other instrument to Oscilloscope itself, I don't know whether my idea is good or Bad, and whether it will work or not.
My question is, how to use the oscilloscope in LabVIEW, since all the instrument drivers are start with VISA handler, here its internal communication from LabVIEW to Oscilloscope there is no external communication through IEEE communication cable, there are other instrument which will communicate through IEEE I am clear on those instrument handling in LabVIEW.
Wr/-
Raikar A G
