How is the WE* pin on the NAT9914 connected to a Coldfire processor?
I'm designing with a NAT9914 GPIB IC and a MCF5307 Coldfire processor.  How is the WE* pin connected to the Coldfire?
Thanx.
(3,969 Views)
I'm not familiar with the Coldfire processor. The 9914 has a generic bus interface that should be able to be connected directly to most processors. The CE* pin indicates to the 9914 when a particular transaction on the bus is intended for the 9914. This is needed because there may be more than one device connected to the processor's bus. Whenever the CE* pin is low the NAT9914 decodes the address lines, WE*, and DBIN. CE* must be driven low during any register read or write to the 9914. If CE* is not low the 9914 will ignore the address, WE*, and DBIN pins.
(3,962 Views)
I have a R/W* pin on the Coldfire processor.  The datasheet for the NAT9914 seems to indicate that on the NAT9914 you can tie the WE* pin and DBIN piin together.  Is that true?
Thanx.
(3,959 Views)
Internally, the 9914 asynchronously decodes register accesses. All of the setup and hold times in the datasheet are referenced to whichever of CE*/WE*/DBIN occurs first or last, respectively.
As long as you meet all the setup and hold requirements you can tie WE* and DBIN together.
Do you plan on using DMA in this application? If so you need to consider the ACCGR* signal also.
(3,952 Views)
