I am using the GPIB-232CT-A to send commands to a network analyser
using the serial coms commands and I am having the following problems:
1) Network analyser only responds to the command only if I reset the analyser.
2) I cannot send more than 2 commands. The analyser only responds to the first command.
Do you know which commands I must use to send more than one command
without having to reset the analyser everytime I need to send the
command.
The command that I use is 'wrt ' .
Sounds like you might not be sending the termination character that the analyzer expects. Check the manual for the analyzer to see what termination character it wants via the serial port. Make sure you're sending this. Doublecheck by running the serial cable into a (another or the same) computer and viewing the incoming data with hyperterminal or NI-VISA.
