How do I make Tektronix Open Choice work over GPIB-ENET?
My goal is to grab screen shots from a Tektronix TDS 2XXX that is connected to a NI GPIB-ENET adapter from a remote computer on the network.  Currently we are using Tektronix Open Choice Desktop to accomplish this when the machine is directly connected to the computer (via GPIB).  When the machine is remote though, Open Choice is 'sometimes' unable to locate the instrument.
I'm pretty sure that this is related to VISA incompatibilities.  The Open Choice program also installs TekVISA which I think may be incompatible with VISA over ethernet (just guessing).
The computer that it does work on:
Had labview 8 and NI-VISA 3.4 installed prior to the Open Choice installation.  After installation of Open Choice a message came up saying: 'The iInstalled visa32.dll is not a Tektronix version of VISA.  Either disable this program by removing it from the Startup directory, or reinstall TekVISA.'.  After removing TekVISA configuration from the startup Menu the Open Choice program worked.
The computer that it doesn't work on:
This computer is used a lot and is very hard to get on.  Labview 8 is also installed, but I don't know which was on there first.  I could be wrong, but I don't think that TekVISA is installed.
What I would like to do is create a way (installation method or other way) to get Open Choice to work over the network on every computer or at least just get an understanding as to why this is happening.
(3,651 Views)
Hi Phil,
For the GPIB-ENET, you have to have NI-488.2 installed.  You can communicate with the GPIB-ENET using VISA, either NI-VISA or TekVISA.  The thing to keep in mind is that only one version of VISA can be installed, either NI-VISA or TekVISA but not both.  It sounds like our NI-VISA is trying to replace the visa32.dll every time TekVISA changes it.  You must uninstall NI-VISA before TekVISA is installed.
(3,636 Views)
