07-19-2013 05:27 AM
All my attempts at changing Programs Folders security settings in Windows 7 has not allowed me to gain access to settings on my GPIB card. I have administrator privileges on my laptop but cannot change my GPIB card primary address.
07-19-2013 07:44 AM
Huh?
The controller card is address 0.
07-19-2013 07:54 AM
If I add a second GPIB card/controller to my PC I should have the option of deciding the primary address of each controller, not just the address that it defaults to.
07-19-2013 08:07 AM
should?
Is that in the documentation?
07-19-2013 08:16 AM
If it is a PCI GPIB card it has nothing to do with Windows. The PCI cards are configured during startup by the BIOS.
And I cannot imagine why you would want to change this.
Kees
07-20-2013 12:50 PM
By default, you must run NI Measurement & Automation Explorer (NI MAX) as Administrator to change these settings. To do this, right-click on the icon and choose "Run as Administrator".
Once you do this, you should be able to change the settings you need. If you want to remove this restriction for future use, you can change the settings from within MAX throughh the following menu opion: Tools->NI-488.2->Require Administrator priveleges.
-Jason S.
