How can I connect a PC as listener or talker to a GPIB controller using GPIB-USB-HS?
I want to connect a PC as an instrument to a Tektronik tester using the GPIB interface. The tester acts as controller and the PC has to act as listener and talker. I want to use for this purpose the GPIB to USB external contriller GPIB-USB-HS. How I can do it?
(3,263 Views)
Hi GAGegov,
The following link has an example (1 in C and the other in LabVIEW) that does this that you may find helpful:
How to use LabVIEW as a GPIB Instrument (non-controller)
Let me know if you have any questions!
Chris R.
(3,242 Views)
