07-19-2011 05:21 PM
I'm currently using an Agilent PSA Series Spectrum Analyzer E4443A which has an internal HD, but not accessible via LAN like the newer Window based Analyzers. I've read the programmer's manual and tried the examples, but no luck. I'm able to send the command in Labview to capture the screen using ":mmem:stor:scr 'C:mal.gif' " and that work's fine. I'm having trouble with using the " :mmem:data? 'C:mal.gif' " Not sure how to handle VISA read calls to get the data to a file. Example attached.
Mal G.
07-20-2011 05:04 PM
Hi Mal G,
What are you experiencing when you run your VI? Are you getting any specific errors? Is the file not showing up in your C drive? How doyou know itis not working?
Perry S.
12-01-2011 03:21 AM
I have the same problem with Agilent E4447.
With the command "MMEM:STOR:C\111.GIF", I can store the .gif file to the E4447 C Drive, but how to transfer the picture to my PC?
12-01-2011 08:33 AM
See here: http://forums.ni.com/t5/LabVIEW/Agilent-E440x-Spectrum-Analyzer-screen-capture/m-p/361469
11-18-2014 06:09 AM - edited 11-18-2014 06:11 AM
I want remote command for save screen shot in .gif and tranfered to local PC means Remote PC. I am using C#.NET for remote accessing.
I dont want use any Drivers,lib.
Thank you in Adavance
11-18-2014 06:12 AM
and i am using LAN.
11-18-2014 07:21 AM - edited 11-18-2014 07:22 AM
@rajup2189 wrote:
and i am using LAN.
Read the programmer's manual.
And if you are asking us to write the C# code for you, that is *your* job.
06-28-2018 01:31 PM
I ran into the same issue and got it working using the Python PyVISA library. I have a working example and instruction on GitHub:
