HP4396B Save Display Screen and Transfer File to PC
I am student research assistant using an existing Labview driver for my HP 4396B analyzer.  It is capability of performing a Sweep, capturing the data, then transferring it to a *.txt file.  My next task is capturing a screen shot of the analyzer screen in TIFF format then transferring it to my PC.  There is a iBASIC code given by the Agilent-HP Programming guide as shown in the attachment.  My problem comes from using this code's logic and creating a labview application from it.  Currently using a  built in function command SAVDTIF 'C:\TEMP.TIF' to capture the screen image onto the analyzer.  I have been unsuccessful in executing the correct order of steps to transfer the binary data from the analyzer file to a new file in labview.
If anyone could walk me through this and give me other resources to understand instrument programming, that'd be amazing.
Thank you!
(1,591 Views)
Hi
Using a simple LabVIEW XY graph is much easier to build a nice graph from the datapoints than downloading a bad display picture.
It is probably easier to make a picture with your phone from the screen as illustration.
(1,587 Views)
(1,488 Views)
Can you send to me the drivers of this VNA, if you have??
(874 Views)
